Nissan Consult Wiring
240Z_Master
Okay, I have a Consult plug from a Z32, and I'm trying to hook it up to the RB25DET harness.
I found this, but helps me a little, it seems like all nissans like to use different colors. Anyone know how to wire this bad boy up? It's only 5 wires, one for ground and one for +12V so that's the easy part. I'm having trouble with the Tx, Rx, and CLK wires.
http://www.plmsdevelopments.com/images_if/consult_if_rev4.pdf
Well, the stock MAF consist of 4 wires. 12V, Ground, and 2 wires that are sheilded that go to the ECU. So isnt that all you have to find out, which 2 shielded wires connect to the MAF? If you have no luck here i know a guy that you can stop by and see that could probably tell you. He's in Gardena.
Uhm, this isn't for a MAF.
For MAF you use this....
http://jimwolftechnology.com/wolfpdf/MAF Z32 CONVERT TO OTHER NISSANS.PDF
So I got a question, on the Consult Connector, I have the four wires for the top left, but the two on the right on top, the CHX and IGN, are those needed because there is no wire out of the harness for the IGN, and the CHX doesnt have a wire coming from the harness.
