280zNHChris Posted April 12, 2006 Share Posted April 12, 2006 I have no front drivers side directional and intermittent passenger front directional, the rears work fine hazard and turn. I took apart the hazard switch and cleaned it and all connectors with elec. contact cleaner. My car is a 72 with an 81 turbo motor with 77 electronics & dash. I also have a78z and pulled the flasher and switched them, same result. I cleaned the light switch on the column with cleaner also. When I put the multimeter in the bulb socket when the flasher is on the meter jumps from 0 to 6-8 volts. I think it's getting all but turing off and on quick for the meter. But the bulb doesn't light. Yet the same bulb lights fine when the parking lights are on. All I can think of at this point is a bad ground but why would the parking lights work fine? This is the last hurdle to get the car inspected. Please advise. Thanks Chris Quote Link to comment Share on other sites More sharing options...
VRJoe Posted April 13, 2006 Share Posted April 13, 2006 Check the grounds, you may need to clean up the mounts also. Quote Link to comment Share on other sites More sharing options...
