auto->5spd swap prep work Z31
MIBPreacher
While I plan on purchasing the tranny this weekend, I wonder if I can install some of the other parts and have it ready for when I get the opportunity later on. I was thinking maybe do the pedal swap and install the clutch cylinder and the line so that when the time comes, everything will be down there already. I plan on building cinderblock ramps to gain more clearance.
Just seeking any input I can get.
Thanks
Rick
you don't need the ECU.
Off the top of my head:
Pull out the old tranny & driveshaft, swap the pedals, install the clutch master/slave/lines, figure out your wiring for the neutral switch & reverse lights, put on the clutch/pressure plate. You need to change the input shaft bushing as well I believe.
Basically everything besides putting the new transmission & driveshaft in.
