savageskaterkid Posted April 21, 2006 Share Posted April 21, 2006 My intake hoses recently took a turn for the worse and I will need some new hoses soon. I was wondering what hoses you guys use when you upgrade your intake system. I'm talking about the TB to AFM hose, and the J-pipe to AFM, and the Turbo to the J-pipe. I don't wanna use jy pieces, i want something new. Does napa or advance, or ect.... make any hoses that would fit here with the correct bung for the hoses that attach to these hoses(sensors). Quote Link to comment Share on other sites More sharing options...
savageskaterkid Posted April 24, 2006 Author Share Posted April 24, 2006 Is everybody just using stock hoses and pipes? Quote Link to comment Share on other sites More sharing options...
Brad-ManQ45 Posted April 24, 2006 Share Posted April 24, 2006 No replacement is made for the boot between AFM and Turbo, and this part is NLA from Nissan. The other hoses can be replaced with the appropriate size silicone hose. The lack of AFM to turbo boot is a good reason to go aftermarket EFI and speed density - eliminating the need for that boot. I will be doing exactly that toward the end of summer. Quote Link to comment Share on other sites More sharing options...
savageskaterkid Posted April 27, 2006 Author Share Posted April 27, 2006 For right now I'm mostly just looking for a TB to AFM hose, I've found similar ones, but they don't have a bung for the idle air sensor. Quote Link to comment Share on other sites More sharing options...
naviathan Posted April 27, 2006 Share Posted April 27, 2006 Figure up the angle you need and get some of those ricer mandrel bent tubing pieces. Any local performance shop should have the mandrel bent angles and some rubber connectors used for cold air intakes. They may also have a piece to fit that will have a bung already in it. If not it can be added by drilling a hole for a proper sized pipe fitting and using a securing nut and plastic/rubber washers on the inside and outside of the fitting. I've thought about this a lot and although i haven't done it myself, I know it will work. Quote Link to comment Share on other sites More sharing options...
