datsun40146 Posted April 22, 2006 Share Posted April 22, 2006 I've just added s12+8 calipers, SS lines, 15/16 MC and a ZX booster. My brakes have little resistance until I press down about 2 inches, then I have good firm brakes. I adjusted the rear brakes with the E-brake reverse method first to try to correct the problem, it really didn't help. So I pulled the drums, the pads are getting a little thin, so I'll replace them before I adjust them manually. Is this rear brake adjustment causing all the play or do I have another problem? I have bleed the brake correctly and in the right order, there is no squishiness, just play with very little resistance and frims up after about 2 inches. The brakes don't suddenly grab after the 2 inches which would be a sign of a improperly adjusted MC, but they don't suddenlt grab, so I don't the MC is my problem. Any Ideas? Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted April 22, 2006 Share Posted April 22, 2006 Common problem. You need to lengthen the metal rod that goes from the brake booster and into the back of the MC. The rod has a built in screw that lets you lengthen it. Just adjust it a couple of times until your brakes start to grab at a good pedal height. Quote Link to comment Share on other sites More sharing options...
