rwdawg2 Posted April 23, 2006 Share Posted April 23, 2006 i have a question and i can't seem to find out enough info on it or this subject of turboing a n/a s130. so i was wondering if i need a crank angle sensor along with a turbo dizzy to make the ignition work. i am going with megasquirt n' spark so i don't know the answer to that either. if anyone can point me in the right direction with this subject or even just the N/a going Turbo project in general i would greatly appreciate it. thank you Quote Link to comment Share on other sites More sharing options...
mobythevan Posted April 23, 2006 Share Posted April 23, 2006 The crank angle sensor is inside the dizzy on an 82 or 83 turbo dizzy, so if you pick one of those up you will not need any external crank angle sensor. I am not familiar with the NA 280zx dizzy. It might be easy to use it with megasquirt. Quote Link to comment Share on other sites More sharing options...
rwdawg2 Posted April 24, 2006 Author Share Posted April 24, 2006 awsome yeah i have an 83 turbo dizzy. and thank you so now for any advice or what should i do geared towards the N/A block Turboed swap. thank you guys Quote Link to comment Share on other sites More sharing options...
rwdawg2 Posted April 24, 2006 Author Share Posted April 24, 2006 bump for any pointers on what i should do to the turbo swap on a n/a block thanks Quote Link to comment Share on other sites More sharing options...
big-phil Posted April 25, 2006 Share Posted April 25, 2006 take a look at all my listing on e-bay or look at this http://forums.hybridz.org/showthread.php?t=110368 Quote Link to comment Share on other sites More sharing options...
rwdawg2 Posted April 25, 2006 Author Share Posted April 25, 2006 here is a list that i have right now stock turbo rebuild t3/t4 440cc injectors pallnet fuel rail (or something equivelent) megasquirt II intercooler 60mm tb 3'' exhaust custom coilovers energy suspension bushings suspension tech. sway bars walboro 255lph and some sort of fuel pressure regulator any thing i might be missing or need advice on please let me know thank you Quote Link to comment Share on other sites More sharing options...
mobythevan Posted April 25, 2006 Share Posted April 25, 2006 The big question I guess, do you have an exhaust manifold to bolt the turbo up? Also what are you doing for the oil drain back from the turbo into the oil pan? Is your turbo water cooled also, or just oil cooled? Looks like you are just down to plumbing up the turbo and the intercooler. What kind of intercooler do you have? Quote Link to comment Share on other sites More sharing options...
rwdawg2 Posted April 25, 2006 Author Share Posted April 25, 2006 ok i have the stock exhaust manifold and i guess i will either buy a stock turbo oil pan or just tap the old used one i have. also my turbo is water and oil cooled which is another delima cus i dont know anything about the water cooled part (where does the water come from and where does is go on the turbo itself?) o yeah and i have a Starion intercooler. thanks again guys this is very helpful in my build Quote Link to comment Share on other sites More sharing options...
rwdawg2 Posted April 27, 2006 Author Share Posted April 27, 2006 bump for any insight or troubles you might have run into while doing your own turbo project. thanks Quote Link to comment Share on other sites More sharing options...
rwdawg2 Posted May 3, 2006 Author Share Posted May 3, 2006 bump Quote Link to comment Share on other sites More sharing options...
Zraced... Posted May 7, 2006 Share Posted May 7, 2006 Your 83 dizzy might not work as the CAS disk inside does not mark the TDC location of the number one piston. You might need the CAS disk from a 84 or newer 300ZX. Just swap it into the 83 dizzy. It has a larger hole for the ECU to recognize the TDC position. I'm not familiar with Megasquirt so maybe someone who runs that can chime in. Quote Link to comment Share on other sites More sharing options...
