My 280z will not start.
Guest Konman156
first things first ... SPARK.... FUEL.... Compression If any one of those are missing then no vroooooom
Start with spark thats the easiest just have someone turn over the car with one of the plugs out of the head and about an inch from the block and see if there is a spark.
Then Fuel take off your fule line and see if it squirts fule when you turn over the car. You can also see if fuel is getting to the cylinders if when you pull the spark plug it is wet and smells like gas.
Then Compression ... I highly doubt that this is the problem but you never know.
If all of those are working right ... you should get vroooooom .... good luck
