Guest wakeboarder_37122 Posted April 26, 2006 Share Posted April 26, 2006 Im looking into getting a 81 280zx turbo although it has the 3 speed auto and I'd defiantly want a 5 speed. What all do I need for the swap, I have the clutch assembly (clutch, line, master cylinder, pedal), driveshaft, Transmission, and shifter/shifter boot. All of this came out of a 79 280zx. Will everything crossover fine, and is the n/a manual trans different from say a 82 turbo manual. One Last question,lol...Do I need a manual ecu, specifically turbo. I know that in 240sx you dont need the ecu so im just curious. no flaming, I searched. thanks, Joe Quote Link to comment Share on other sites More sharing options...
280Z Turbo Posted April 27, 2006 Share Posted April 27, 2006 I have a 1976 280Z/1981 280ZXT hybrid, so maybe I can help a little bit. That trans will bolt up just fine and the ECU will work fine too. I have a 1978 5 speed and 1981 ZXT Auto ECU on my car. The only difference I notice with the Auto ECU is that the revs stay up a little longer between shifts which is actually nice because it makes it smoother. You probably will need to use a different driveshaft and you may have to swap the differential flange (which is a PITA). I've never done an auto to manual swap, so I can't tell you much more. Quote Link to comment Share on other sites More sharing options...
AE2ZX Posted September 30, 2006 Share Posted September 30, 2006 i know this is a older thread ,but i just did this swap and there is a bit of a change in the bellhousing tickness where it bolts to the block . also you will have to swap drivlines aswell . Quote Link to comment Share on other sites More sharing options...
username Posted October 1, 2006 Share Posted October 1, 2006 after you remove the torque convter bushing from the crankshaft, remember to install a new pilot bearing.. i forgot mine when did it. i did this swap on my 81 zxt about 12 years ago. the flange on the diff is a different size than the 79. so either remove the diff flange, or buy a turbo 5 sp and drive shaft. Quote Link to comment Share on other sites More sharing options...
