Something wrong?
240Z_Master
It sounds like $hit btw because the O2 sensor was just dangling in back of the turbo, I just was too anxious to get it started and zip tied the O2 sensor...
Tommorow the downpipe gets made, I have to find some damn M6x1.0 fittings for the boost controller, and do a few more things.... but MSA is on Sunday, and I am running it down to the wire!
Oh yeah, someone remind me to put my registration sticker on my car, it still says 2005 and I have the 2007 sticker on my desk, lol.
Sounds like a vac. leak like you said, I don't think the o2 would affect the idle like that though. hopefully your ilde control valve and air reg air working properly. If i recall, you removed your CAS, remember to check your ignition timing.
But the bottom line is, Its alive!
Sounds like a vac. leak like you said' date=' I don't think the o2 would affect the idle like that though. hopefully your ilde control valve and air reg air working properly. If i recall, you removed your CAS, remember to check your ignition timing.
But the bottom line is, Its alive![/quote']
I've pretty much have to do everything, I'm just surprised the damn thing started so easy.
Saw you posted in another thread that you were running a stock FPR.
Can you do a file of you revving your car without the bov connected? Its kinda hard to tell if its running rich because of the vented BOV or because fuel pressure is all outta wack.
Dude that is some serious black smoke LOL.
Evan
Evan
At least it sounds better than when I first cranked her to life!
Oh yeah, the BOV is closed when I'm on the revs...sooooo?
Snag that FPR from palmdale. Thats a pretty good deal. Ill bet that it helps alot.
Good point about the 3-4k rev thing. If its acting like its bouncing off a rev limiter there and will not rev beyond its in limp mode because of the MAF. I had to deal with this when I put mine together. I had some bad maf wiring.
Your right though, it does sound much better!
Nice project btw!!
Evan
sounds good dude' date=' esp the BOV. oh by the way my friend has a nismo FPR in palmdale for 100 bucks.
can you get the revs past 3, 4 k?[/quote']
Hey Myron, hook me up with the FPR... My tach isn't working correctly so I have to check all the wiring and figure it out.
