Desperate Need help w MM brake install. (Pics)
I order a lot of parts at once from Moder Motorsports, so I got the
Billet R230 CV Adaptor, 70-78 Z Car
and
The 13" front extreme brake package.
I may have lost something. It is late and I am tired. I have (20) twenty 10.9 Bolts that will go into the axle cv's and the front hubs. I do not know which. they look a little short for the front I do not know. Can some one clue me in on the hardware for this package?
Those silver bolts with the flanged heads look just like the ones that came with my MM CV axles as well (20 also) I don't have the MM brake kit so I can't comment on the type of bolts to use with the brake kit, but from your pics the silver bolts do look a bit short for the hubs.
Are they the same as the OEM off gray R200 bolts CV bolts? Do they have seperate lock washers or that they have a intergral washer-head? thanks.
Cyrus, I believe you're asking if the CV bolts are same as the rotor to hub bolts? The rotor to hub bolts we supply are the same as the OEM nissan ones you had with prior factory setup. These are not same as the R230 CV bolts. Our CV hardware is packaged separately from rotor hardware etc and typically labelled as such.
Looking forward to a direct email from you.
