Guest kickingriffin Posted May 1, 2006 Share Posted May 1, 2006 hello all. i have got a RB25DET engine that most of you know im fitting in my bmw. i plan too tune it a little but not sure what mod`s too go for. i already have: front mount intercooler free flow air filter free flow exhaust system with cat removed. every think else standerd any other mods i can do i plan to fit a upgrade fuel pump (255lph) i also would like to turn the boost up a bit but not sure how much i can go with out spending big money or causeing any harm. any idears on this subject? Quote Link to comment Share on other sites More sharing options...
Guest Fulcrum Posted May 1, 2006 Share Posted May 1, 2006 An HKS Vein Pressure Converter would be a good mod if you can find one. HKS doesn't make them any more but you might be able to find one used. It replaces your entire AFM and then uses a MAP sensor to fake the signal to the ECU. You shouldn't have to do too much more. Just turn up the boost and fuel and you'll have way more power than you need. Quote Link to comment Share on other sites More sharing options...
Guest kickingriffin Posted May 1, 2006 Share Posted May 1, 2006 can you give me some more info on this please!!! can i keep my standerd ecu with this? is it hard to wire in? what dose it do? what are the weak links in the RB25det engine? Quote Link to comment Share on other sites More sharing options...
Racinjitter Posted May 1, 2006 Share Posted May 1, 2006 If you have a ceramic impeller on your turbo dont turn up the boost past 12-14 psi. The ceramic impellers arent meant to spin as fast as a metal impeller. Quote Link to comment Share on other sites More sharing options...
Guest kickingriffin Posted May 1, 2006 Share Posted May 1, 2006 yeah have ceramic impeller so have i got to do any think else or can i just turn the boost up to 12psi? Quote Link to comment Share on other sites More sharing options...
Racinjitter Posted May 1, 2006 Share Posted May 1, 2006 I believe that you can just turn it up. Quote Link to comment Share on other sites More sharing options...
Guest kickingriffin Posted May 2, 2006 Share Posted May 2, 2006 how much can i turn it up too? what psi with out melting a piston? cheers Quote Link to comment Share on other sites More sharing options...
Racinjitter Posted May 2, 2006 Share Posted May 2, 2006 you wont melt a piston with the stock turbo. With the right tuning you could probably squeeze 22-28 psi before meltdown. Quote Link to comment Share on other sites More sharing options...
Guest kickingriffin Posted May 2, 2006 Share Posted May 2, 2006 will i have to get it re-maped to do this? ive been told i can run max of 12psi boost. when i get her up and running ill let you know how i get on at 10psi. cheers Quote Link to comment Share on other sites More sharing options...
Evan Purple240zt Posted May 2, 2006 Share Posted May 2, 2006 You have a high volume pump right? You really need to get some sort of aftermarket fuel pressure regulator. The factory FPR does not have a high enough flow rate to sustain the lph from an aftermarket pump. Do not go above 14psi of boost else the wheels of the turbo disentegrate. You can use a nissan z31 turbo, its simaler size wise but has metal wheels. Set your base timing to 17 intead of 15 degrees. If you blow your motor up thats your problem. I did this before I bought my power FC and it did make the car run better. If you are not familiar with tuning, maybe its a better idea not to. The factory curves are very rich, and alot of power can be had with a good tune and EMS system. Evan Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted May 2, 2006 Share Posted May 2, 2006 Come to think of it, I might need a regulator with this 255 Walbro I'm running. Quote Link to comment Share on other sites More sharing options...
ZXRockie Posted May 2, 2006 Share Posted May 2, 2006 Come to think of it, I might need a regulator with this 255 Walbro I'm running. are you running in-tank pump? Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted May 2, 2006 Share Posted May 2, 2006 are you running in-tank pump? External Walbro 255 Quote Link to comment Share on other sites More sharing options...
Evan Purple240zt Posted May 3, 2006 Share Posted May 3, 2006 Yeah if ANYONE is running a big pump replace the regulator. I have an intank walboro pump and I know several people who had problems before swapping to an aftermarket regulator. If you search for the nismo unit your golden. Evan Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted May 3, 2006 Share Posted May 3, 2006 Yeah if ANYONE is running a big pump replace the regulator. I have an intank walboro pump and I know several people who had problems before swapping to an aftermarket regulator. If you search for the nismo unit your golden. Evan I think this might help my running rich problems. Quote Link to comment Share on other sites More sharing options...
Evan Purple240zt Posted May 3, 2006 Share Posted May 3, 2006 Me too. I did not find this out personally but its kinda common knowledge over on the 240sx boards. I swapped my FPR when I did my motor swap. There is a post in another thread about your car, some dude says he has a freind who has one for 100 bucks. Thats a good deal. Evan Quote Link to comment Share on other sites More sharing options...
240Z_Master Posted May 3, 2006 Share Posted May 3, 2006 Me too. I did not find this out personally but its kinda common knowledge over on the 240sx boards. I swapped my FPR when I did my motor swap. There is a post in another thread about your car' date=' some dude says he has a freind who has one for 100 bucks. Thats a good deal. Evan[/quote'] Yeah I think it's Myron Quote Link to comment Share on other sites More sharing options...
