300zxRB26 Posted May 3, 2006 Share Posted May 3, 2006 so i ran the diagnostics today on my car and i got code 11, 12, 13, 33, and 42. The crank position sensor, my MAF sensor, my fuel temp. sensor, my O2 sensor, and my head temp. I've been lookin around and can't find anything on the fuel temp. sensor or the crankshaft position sensor. Any suggestions where i can get these besides a dealer. I guess all these problems would solve my hesititation and chugging problem wouldnt it? Quote Link to comment Share on other sites More sharing options...
Guest Roscoe Posted May 3, 2006 Share Posted May 3, 2006 all of them bad at once? not likely. check and see if these sensors all use a common ground. if they do thats your problem. this may not apply to your car (i dont know much bout nissans in pictular) but its worth checking into! Quote Link to comment Share on other sites More sharing options...
mtcookson Posted May 3, 2006 Share Posted May 3, 2006 crank angle sensor is located in the distributor so check the wires going to that. i know of the fuel temp sensor... but i have no idea where it is off hand. i've not been into the Z31's all that much, mostly Maximas. Quote Link to comment Share on other sites More sharing options...
Racinjitter Posted May 9, 2006 Share Posted May 9, 2006 the fuel temp sensor is the little part sticking out of the fuel pressure regulator, one wire connected to it.. You are best off going to a junkyard to find one. But you do not need it as it does not change anything in the PCM parameters. On one of my Z31's the fuel temp sensor has been broken for years and no problems. I agree with roscoe, it is highly unlikely that all of those sensors went bad at the same time. Check your grounds. There are a few that connect to the plenum, and then one that connects to the body, straight from the engine harness. Quote Link to comment Share on other sites More sharing options...
