fl327 Posted November 8, 2000 Share Posted November 8, 2000 i would like, well really desperately need, to upgrade my brake system here, last night in the rain fishtailed downshifting and standing on the brake pedal and i know i need these brake the forums that document this swap say things like shims and adaptor plates all over them, i have no idea what these things are, can someone who has done or is familiar with this swap school me in laymans terms what to get and what to do, any advice would be greatly appreciated. and also, my worst nightmare is that when i do it, the wheels wont fit back on do you know if they will fit with 205-70-14 with the famous 280zx mags on a 240z combo???? thankz guys, i had have one sorry car if it werent for you../.. Leonard four pistons pleezzzz!!!!!! Quote Link to comment Share on other sites More sharing options...
MYRON Posted November 9, 2000 Share Posted November 9, 2000 Its an easy swap, At least it was on my 77.. Go to the local auto parts store and buy a set of rebuilt calipers from an 84 Toyota 4x4 pickup. They may ask what engine tell them the V6. You may also want to look in the box and make sure that they are the 4 piston units... remove the old ones, take a pair of sheet metal sheers and trim the dust shield so the new ones will fit... Make sure the when you install the new ones that the bleeder valve is on the top side of the calliper. If you do not you will never be able to bleed the brakes... And the best part: take your old ones back and get your core charge back. I think that the whole process cost me around a hundred bucks!.... Myron Quote Link to comment Share on other sites More sharing options...
fl327 Posted November 9, 2000 Author Share Posted November 9, 2000 Thanx Myron, by the way, did you need any adaptor plates, shims or anything like that, i have a 280zx brake master cyl ready to go, does that require any mods to install as well??? and what kind of tires did you have on the 77? im afraid that my 205-70-14s with 280z six spoke mags wont fit......!!! Quote Link to comment Share on other sites More sharing options...
MYRON Posted November 9, 2000 Share Posted November 9, 2000 Your welcome... I didnt notice the the size was that much bigger than the factory units but I did this swap 6 months ago.... I am using 16x8 weld draglites so I actually have a ton of room under there... I dont remember having to use any shims or anything like that..... I have no idea about the booster. Myron Quote Link to comment Share on other sites More sharing options...
Arif Posted November 10, 2000 Share Posted November 10, 2000 I agree with Mike. When I did the swap on my 78 I used 300ZX vented discs and I think that was the key to improved braking. I also used the 280ZX master cylinder and it bolted right up with no mods needed. Quote Link to comment Share on other sites More sharing options...
Guest scca Posted November 10, 2000 Share Posted November 10, 2000 you must be talking about solid rotors..... IMO not worth it , a stock Z caliper can lock up the brakes just fine. why add more pistons? if your calipers dont work thats a different issue.. what z needs is larger rotors and to do this you will need a spacer to center the caliper over the rotor. ------------------ Mike mike@fonebooth.com http://www.fonebooth.com/brakes.html raceparts and brake upgrades. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 28, 2000 Share Posted November 28, 2000 The ZX master should fit rite in. I have a 70Z and the 82ZX master bolted up to my vacume with one mod. The ZX master has flanges for 4 bolts you may have to cut one of these flanges off. Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted December 1, 2000 Share Posted December 1, 2000 Heh, yeah if the brakes are lockingup now then bigger brakes won't help. Sounds like only the rear locked up though - if that's true and the fronts just couldn't hang then an upgrade is great. FWIW - I've got the solid conversion on my front end. I didn't do it and I don't like it but it DOES stop fairly well. Not hard repeated stops mind you but a single panic stop would be just fine so long as I wasn't doing 100+ Mine will be coming off "soon" I hope so I'll be letting them go here cheap cheap. No spacers for the brakes near as I can tell... Quote Link to comment Share on other sites More sharing options...
