AK-Z Posted May 5, 2006 Share Posted May 5, 2006 How it handling using the Z rack and pinion? Just curious. Quote Link to comment Share on other sites More sharing options...
SR240Z Posted May 5, 2006 Share Posted May 5, 2006 we have no problems at autox with our sr20 car, it handles great with the right set of tires Quote Link to comment Share on other sites More sharing options...
AK-Z Posted May 5, 2006 Author Share Posted May 5, 2006 Ok, thanks. I was wondering because my KA24de came with a powersteering pump and was debating why I should even use it. If it handles better with a lighter engine, then I don't see a reason to bother with it. Another question. I was thinking about going supercharger on this. I think something like a eaton would be to big for my application. I was thinking something like whats on the mazda millenium. Does any one know who make that s/c? I know tuning for peak efficiancey will be hard to attain, but I am use to NA motors anyways. And I think that it a better application for a KA24DE with stock internals. Any othe s/c you guys suggest for a 2.4L? If I wanted to turbo it I would rebuild the motor with turbo in mind (new internals, lower compresion, ect., but cost $$$). Any suggestion on anything? Quote Link to comment Share on other sites More sharing options...
Hugh Posted May 5, 2006 Share Posted May 5, 2006 If you're going with a supercharger, you should use a centrifugal type (like a Vortech) Use an aftercooler to keep the temps down. You could pop that motor with a roots type supercharger pretty fast... unless you build it, I guess. Oh, my steering rack is great stock. The car handles beauifully with poly bushings and tokico springs/illuminas Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted May 5, 2006 Share Posted May 5, 2006 Why not go KA-t? They get some nice numbers with pretty low boost. Mario Quote Link to comment Share on other sites More sharing options...
AK-Z Posted May 5, 2006 Author Share Posted May 5, 2006 Quote Why not go KA-t? They get some nice numbers with pretty low boost. Mario 2 reasons, fabbing exhaust system and I'm lazy, lol. I find it easier to fab up brackets than an exhaust manifold and location won't really be a problem since I'm goin to be removing the p/s pump. Tuning fuel maps will be different, But I think it will be slightly easier to setup with a s/c. Set fuel by rpm because boost will be controlled by crank. I like throttle response more than power. And to up boost, all I would need would be a pulley. And again I'm lazy haha. Another thing, would it be wise to put a front mount IC? How big? I was thinking of putting the smallest pulley and controlling the amount of boost using a BOV. does that sound like it will work? Quote Link to comment Share on other sites More sharing options...
rb26zed Posted May 15, 2006 Share Posted May 15, 2006 Quote Another thing' date=' would it be wise to put a front mount IC? How big? I was thinking of putting the smallest pulley and controlling the amount of boost using a BOV. does that sound like it will work?[/quote'] There is a rather big name turbo nissan tuning shop here in australia that use the BOV method for controlling boost on their turbo cars almost exclusively so I cant see why it wouldnt work in your application. Yes I believe it would be wise to use a front mount IC here as I assume this was a N/A KA engine. Size, I would use something around 500mm x 250mm x 75mm Quote Link to comment Share on other sites More sharing options...
jdizzy204 Posted May 16, 2006 Share Posted May 16, 2006 if u decide to change ur mind about turboing ur ka. i suggest u check out ka-t.org. heres a great guide on rebuilding the ka. i say u boost it:flamedevi http://www.ka-t.org/forums/viewtopic.php?t=4156 Quote Link to comment Share on other sites More sharing options...
