VG30 V6 NA add a tiny Turbo ?
Guest toadnz
Guest toadnz
I'd like to turbo an NA, simple yep,
lets say I can add intercoolers, water, oil, wastegates,downpipes as needed, and rewrite ecu rom to handle the additional fuel maps etc.
AH, but the turbos themselves, as its high compression I dont need
much boost, but very accurate boost control, so smaller turbo with
small waste gate to control !
any ideas of makes and models for this, no more than a nats breath of
boost,
So what is sensible max boost with STOCK NA engine ?
And quickest smallest, lightest, turbo to get me there ?
Also, if any turbos dont need the oil or water cooling, so much
the better, but I dont know of any.
thanks for your time,
toadnz
You can go even higher then that becuase the n/a motor is only like 9:1 compression there have been cars known to do over 600+hp on 10:1 and higher. It's all in the tunning to be honest also the VG's technically came with froged Mahle pistons and rods so go for the gold.
Don't take this the wrong way' date=' but do you have any evidence of that fact bob?
Dave[/quote']
Yeah,we had a HUGE discussion of it on maxima.org take a look it's long though.
READ ON:
http://forums.maxima.org/showthread.php?t=453589
As a matter a fact it was a thread started by amember of this board.
EDITL wrong car found the cover pic though
