240hoke Posted May 23, 2006 Share Posted May 23, 2006 Hey guys, Im looking for a center "turnbuckle" type adjuster piece. Its used in the center of some strut bars for adjsutment. Its basically a piece with right hand threads on one side and left and threads on the other that can be used to spread a tube. Ive been having trouble finding on jsut curious if anybody might knwo where to find one. Looking for something along the lines of 1/2-3/4 Thanks! Quote Link to comment Share on other sites More sharing options...
JMortensen Posted May 23, 2006 Share Posted May 23, 2006 Coleman Racingn and AFCO sell both aluminum and steel tubes. These are threaded RH and LH so they work as a turnbuckle. http://www.secureperformanceorder.com/afcostore/getsubclasses.cfm?ClassID=87&CategoryID=8 http://www.secureperformanceorder.com/afcostore/getsubclasses.cfm?ClassID=117&CategoryID=8 http://www.colemanracing.com/ Quote Link to comment Share on other sites More sharing options...
240hoke Posted May 24, 2006 Author Share Posted May 24, 2006 Thanks Jon, Ive seen those before. A local shop around me carries them and I may end up using a swaged tube. I was hoping to just find a threaded piece for the middle though. I am doing you and terry's rear toe adjuster mod, although it will end up being much like yours. Thanks for teh pictures etc!! Im in the middle of extensive drivetrain modification. Everything is out from under the car, thought I would finally throw the finned cover on. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted May 24, 2006 Share Posted May 24, 2006 If you just need a short male LH and RH threaded piece, you could try http://www.mcmaster.com. Get a LH and RH threaded stud and just weld a nut onto the stud to put a wrench on, or maybe even just grind a flat in the middle of the stud to grab with a wrench. Quote Link to comment Share on other sites More sharing options...
Drax240z Posted May 24, 2006 Share Posted May 24, 2006 In my experience you have to make them... If you find a source for these that are stocked and on the shelf please post it up. Quote Link to comment Share on other sites More sharing options...
