240z E88 Head Mated To A 280z Intake Manifold
ozzinc
I wondering if I can use A 280z intake manifold on a E88 240Z HEAD
I have A p90a head which is hydraulic and non adjustable,
I know I would have to drill some holes for the injectors and the intake mounting screw holes.
Thanks for the info, I was going to try and have a machine shop make up a custom fittting, but if I can get these timeserts to work then I will just go with that. which is good because I had the p90a head ported and polished and it has larger stainless steel manley valves, so I was trying to figure out a way to make this setup work, the regular p90a head would never be able to handle the hp that im trying to make and the head would begin to have valve spring float basically collapsing under extreme hp loads.
I will go to the thread that you directed me to, and see if I can get a part number for the timeserts.
