Steven280zx Posted June 2, 2006 Share Posted June 2, 2006 I need some help with my 1982 280zx. First, this car has been sitting outside abandoned for about 10 years and i dont have very much mechanical experiance. Its an L28E NA inside there and im hoping to get a turbo into it once its fixed. I'm wondering whether to fix the stock L28E or to buy and put in a L28ET. I searched all the forums and couldn't find any advice on this but if i missed it sorry about that. Quote Link to comment Share on other sites More sharing options...
zeiss150 Posted June 2, 2006 Share Posted June 2, 2006 this should answer all of your questions about a turbo swap. http://forums.hybridz.org/showthread.php?t=104196&highlight=n%2Fa+turbo the quick answer to your question is that yes you can turn your N/A L28e into a turbo motor. you'll find that there are about 50 different ways to do it. Your N/A block is the same as a turbo block, the pistons are different and the head is differnt (with a differnent cam) there is also different injectors, distributor, exaust manifold, and a bunch of other little parts that I don't want to get into. if you are going to build a turbo engine do lots of research before you start, because you only want to do it once. good luck and let us know if you have any questions. Quote Link to comment Share on other sites More sharing options...
Steven280zx Posted June 2, 2006 Author Share Posted June 2, 2006 hey thanks zeiss i must have missed that when i searched Quote Link to comment Share on other sites More sharing options...
