gearheadstik Posted June 2, 2006 Share Posted June 2, 2006 Hey guys...let me first say i have done lots and lots of searching before asking about this. I'm trying to find some wheels for my ls1 240z...I plan on going 17in by 9.5,10, or 10.5. This car is going to be a street car mainly and may be up the occasional track day. The z will have zg flares installed with a 10in ground control coilover. I think i like NAZARs centerlines which are 9.5s front and rear.... ON3GOs ccw wheels on the hulk also look great, which i read are 10.5 on the rear. Does anyone know if these two example have clearence issues with the flares they use? Please make reccomdations...the only thing i ask, is that i dont have to have to run wheel spacers...i did this on my 280z and it didnt work out like i had planned for. I also have the toyota calipers on the front and might move up to the 12 or 13 in rotors w bigger calipers at some time. I also use oem 4 lug hubs...Anyone with experience please share so i dont make a costly mistake, i would be open to any style wheel as long as it is a 17x9.5 plus...please foward this to anyone that you think might have some advise....thanks Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted June 2, 2006 Share Posted June 2, 2006 Depending on the back space they'll work fine. I have 18x9.5's on all four corners. They have a 5.5" backspace. The front fits perfectly in the fender under ZG's but the back will likely need a spacer to push it out slightly(for my tastes anyway). It's tucked up under the flare a good amount. More than I like. It'd be great if you wanted to slam it on the ground. I am about to install ZG's on another car and will try to post pics when I get them done. Quote Link to comment Share on other sites More sharing options...
BringIt Posted June 2, 2006 Share Posted June 2, 2006 Depending on the back space they'll work fine. I have 18x9.5's on all four corners. They have a 5.5" backspace. The front fits perfectly in the fender under ZG's but the back will likely need a spacer to push it out slightly(for my tastes anyway). It's tucked up under the flare a good amount. More than I like. It'd be great if you wanted to slam it on the ground. I am about to install ZG's on another car and will try to post pics when I get them done. Can we see pictures of that? 18x9.5s on all 4 Corners. I was looking towards some aftermarket 350z wheels. That were 18x9 and 18x10s I think with Coilover and some adapters I could get them to fit. Quote Link to comment Share on other sites More sharing options...
gearheadstik Posted June 2, 2006 Author Share Posted June 2, 2006 What kind of wheels are they? The 18s that is... Quote Link to comment Share on other sites More sharing options...
JIM73240Z Posted June 2, 2006 Share Posted June 2, 2006 i am getting ready to do the same thing. i am going to mock up my flairs to cliftons silver car to get the back space right for a set of ccw 17" x 10" in front and 11" in the rear with the azcar suspension and 5 lug brake conversion. should look mean as hell. jim Quote Link to comment Share on other sites More sharing options...
Dudeboy Posted June 3, 2006 Share Posted June 3, 2006 I have look at every wheel and tire combination on the market. If you are looking at more of race/street wheel (custom size, offset and backspace) prepare to spend some money: Simmons Wheels, Kodiak , Complete Custom wheel, Bogart, Kinesis, Jonbloed and RS Watanabe (spelling?) Racing Panasports. With these wheels prepare for a wait time to build. In your Billet- there is Budnik, Billet Specialties, Bonspeed and Intro Wheels-there are some other billet wheels out there, but you are limited to bolt pattern and offset/backspace. Check out Image wheels in the United Kingdom, they will make any bolt pattern or offset you desire, and they have vintage to modern choices of wheels. Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted June 4, 2006 Share Posted June 4, 2006 My wheels on Mikelly's car. It looks just like my car, for now! I just cut his fenders for the flares and welded the seam. The wheels are Centerline Meteors. Mike will be going with CCW or something racer-like like that. Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted June 4, 2006 Share Posted June 4, 2006 Forgot to add this car uses Coilovers and a 5/8" spacer I believe. I think the wheel will just barely fit without the spacer but coilvers are a MUST. Also the tires are 275/35/18 BFG Drag Radials. The wheel is a 18x9.5. Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted June 4, 2006 Share Posted June 4, 2006 Quote Link to comment Share on other sites More sharing options...
gearheadstik Posted June 4, 2006 Author Share Posted June 4, 2006 Man....those are sharp...could you have done it without the spacer if your backspacing was different?? what type of 5 lug setup is that??? Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted June 4, 2006 Share Posted June 4, 2006 I'm pretty sure they fit without the spacer. Probably a 9" with a 5" BS would put the wheel in the same location and would not require a spacer to push it to the edge like this shows. The drag wheels I'm going to go are 15x10 and will have a 5.5" BS and I'm expecting them to fit without a spacer. At least I hope. LOL I'm not sure exactly which set-up he's using. I'm pretty sure it's stock hubs re-drilled with a Z31 rear rotor but that's all I know. Like I said, this is not my car, I just stuck my wheels on for pics for you guys. I was doing the flares anyway and figured what the heck! Quote Link to comment Share on other sites More sharing options...
240zwannabe Posted June 6, 2006 Share Posted June 6, 2006 well if you've got 5 lug....http://mustangtuning.com/deepdish3.html it makes me want 5 lug sooooo badly Quote Link to comment Share on other sites More sharing options...
240zwannabe Posted June 6, 2006 Share Posted June 6, 2006 but would 17*10.5 wheels fit without any modifications? if so i might just go for the conversion Quote Link to comment Share on other sites More sharing options...
v8dats Posted June 6, 2006 Share Posted June 6, 2006 if you're talking about the for wheels then a small spacer would be needed even with coilovers. i think speeder covered that. i was looking at the fr500's. not a bad price. Quote Link to comment Share on other sites More sharing options...
nazar Posted June 7, 2006 Share Posted June 7, 2006 17x9.5 all around, 275/40/17 rear, 255/40/17 front 5" bs all around, makes for a nice lip Front with no spacers actually cleares the fender if you flare it slightly and roll the lip The rear sticks out because of the bigger tire, a ZG flare should swallow it up, i will be getting the MSA street flare all around, and push the front wheels out some with spacers if need be to fill out the flare You will need coilovers all around, althought my fronts actually clear the strut barely if you slightly grind down the bottom cup of the strut Quote Link to comment Share on other sites More sharing options...
jdizzy204 Posted June 7, 2006 Share Posted June 7, 2006 whats the widest centerline makes those wheels nazar? Quote Link to comment Share on other sites More sharing options...
gearheadstik Posted June 7, 2006 Author Share Posted June 7, 2006 Those look realy good nazar...do they scrud when you go over bumps??? Do you plan on cutting any where?? Quote Link to comment Share on other sites More sharing options...
nazar Posted June 8, 2006 Share Posted June 8, 2006 if u look close the rear fenders are cut out, still waiting for flares the widest centerline makes those is 9.5 but the beauty is that they will make it in our bolt patteren:) Quote Link to comment Share on other sites More sharing options...
