cheftrd Posted June 3, 2006 Share Posted June 3, 2006 Don't know if this has been put out or not, but Nismo is now selling Engine parts used in the their GT500 and Nur24H race engines. GT Engine Block 11000-RRR45 Y258,000 (I believe it's a modified and strengthend N1 block) GT Crankshaft 12200-RRR4A Y298,000 (77.7mm stroke. stronger than stock, dynamic balance, modified fillet roll, 87mm bore and GT rods for 2771cc) GT Connecting Rods (CrMo) Spec 1 119.5mm 12100-RRR4A Y20,000 Spec 2 121.5mm 12100-RRR4B Y20,000 GT Head Gasket 1.2mm 88mm bore 11044-RRR4A 1.8mm 88mm bore 11044-RRR4B GT Intake Gaskets 1617S-RRR45 Y3000 (Six steel gasket set for the inner and outer on the throttles) Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted June 3, 2006 Share Posted June 3, 2006 Don't know if this has been put out or not' date=' but Nismo is now selling Engine parts used in the their GT500 and Nur24H race engines. GT Engine Block 11000-RRR45 Y258,000 = $2,300 aprox (I believe it's a modified and strengthend N1 block) GT Crankshaft 12200-RRR4A Y298,000 = $2,600 aprox (77.7mm stroke. stronger than stock, dynamic balance, modified fillet roll, 87mm bore and GT rods for 2771cc) GT Connecting Rods (CrMo) Spec 1 119.5mm 12100-RRR4A Y20,000 Spec 2 121.5mm 12100-RRR4B Y20,000 GT Head Gasket 1.2mm 88mm bore 11044-RRR4A 1.8mm 88mm bore 11044-RRR4B GT Intake Gaskets 1617S-RRR45 Y3000 (Six steel gasket set for the inner and outer on the throttles) Outch.... I added the conversions... Quote Link to comment Share on other sites More sharing options...
Guest JAMIE T Posted June 3, 2006 Share Posted June 3, 2006 Is the crank full counterweight? It had better be for $2600! Quote Link to comment Share on other sites More sharing options...
cheftrd Posted June 4, 2006 Author Share Posted June 4, 2006 Is the crank full counterweight? It had better be for $2600! Nope... Quote Link to comment Share on other sites More sharing options...
