L24 Cam info
wardie
Hi All, I am a total noob re the internals of a motor when it comes to modifying one.
Can anybody assist me with some info or opinions on what the following cams will do for my L24E motor. As far as I know it's a standard build motor and I am looking at what bolt on power I can use. I do not want something that hates the daily city grind.
The cams available to me today are 68, 72 & 74 degree regrinds.
Thanks in advance
Wardie
Ok I'll ask the vendor for the suggested details.
Offline I have been told that I should look for a 260Z (L26) cam instead of trying to use one of these regrinds as I have not modded anything else on the motor and the L26 cam is better than the L24.
Can anyone confirm this?
Thanks
Wardie
Guest exa41
hi wardie. the original sss cam 4 cyl is some where between 68 &72 degrees, although the 74 is a little lumpier it will still work with the injection and you wont have any problems with valve clash.
If you ring CLIVE Cams in melbourne he will certainly help you.
exa41
