Guest wakeboarder_37122 Posted June 10, 2006 Share Posted June 10, 2006 I have a 81 zxt that i put suspension tech. springs with tokico blue struts. What would be my best bet to get the camber/toe straightened out? motorsport auto has the offset camber bushings for the front,and tirerack. but i cant find one for the back. one more thing, are camber plates even possible with struts/springs combo. thanks for the help, please no flaming i searched. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted June 10, 2006 Share Posted June 10, 2006 You need to slot the rear crossmember to make it adjustable for camber and toe. A slotted crossmember is kind of hard to adjust, generally you do it with a prybar when the car is on the alignment rack, which can be kind of difficult if you don't know what you're doing. MSA used to sell a kit that had adjusters for this, I think they don't have it anymore. it's a pretty simple setup and other styles of adjusters have been used, I seem to remember someone using a Mercedes adjuster. Anyway, if you search "slotted crossmember" you should find some stuff, and if not try 510 sites. Those guys have basically the same suspension and they're 10+ years older than ZXs so they've been down all these roads and you can copy a lot of stuff that they're doing. Quote Link to comment Share on other sites More sharing options...
