racerx260 Posted June 14, 2006 Share Posted June 14, 2006 Putting a new n54 block in with 83 turbo ecu and harness. The n/a n54 block is not tapped for the knock sensor. Can it be drilled and tapped?Does it go all the way through or into a solid casting? Quote Link to comment Share on other sites More sharing options...
olie05 Posted June 14, 2006 Share Posted June 14, 2006 knock sensor? Are you thinking about the cylinder head temp sensor? (the little thing in the back part of the right side of the head? also, theres the F54 block, and the N42 block, but no N54 block. N42 was the N/A block, F54 was turbo. Quote Link to comment Share on other sites More sharing options...
big-phil Posted June 15, 2006 Share Posted June 15, 2006 I did it to my n/a block, Let me think, you know the smaller bolt holes just under the head? I drilled it out about a 1/4 inch? I theaded the smaller size bolt into the hole, measured how much it went in, then drilles it that much with the size drill bit for the tap that matched the threads on the knock sensor ( i put tape on the drill bit so as to not go too far) then tapped it as much as I could, and installed the sensor. Quote Link to comment Share on other sites More sharing options...
racerx260 Posted June 15, 2006 Author Share Posted June 15, 2006 Thanks, sounds like a plan. Quote Link to comment Share on other sites More sharing options...
racerx260 Posted June 15, 2006 Author Share Posted June 15, 2006 olie05. Sorry an n/a f54 block used on 82 and 83 n/a 280zx motors . same as turbo f54 but the knock sensor hole is not open. . below head temp to the left of oil filter.There is a raised area but no hole. I am going to drill and tap it . Quote Link to comment Share on other sites More sharing options...
TheNeedForZ Posted June 16, 2006 Share Posted June 16, 2006 big-phil, Looks like one smart way to ensure safe running of the L engine. Does the setup work? Quote Link to comment Share on other sites More sharing options...
big-phil Posted June 16, 2006 Share Posted June 16, 2006 I have never had a true turbo motor, but I have 15 pounds boost with no knock, I guess its working? Quote Link to comment Share on other sites More sharing options...
