Chewievette Posted June 18, 2006 Share Posted June 18, 2006 I have looked everywhere I can think of to find a set of LD28 connecting rods. The only place I found that can even get them is the Nissan dealer and they have to order them in from Japan at $140 EACH! I was hoping to find some one who bought the whole motor for the crank but I've had ads on all the Z sites and no replies. If you guys know of any place that might have them, let me know. Thanks. Quote Link to comment Share on other sites More sharing options...
1 fast z Posted June 18, 2006 Share Posted June 18, 2006 I have a few sets but I have long rod plans also, but mine are going to be lightened in non structeral places. Quote Link to comment Share on other sites More sharing options...
Chewievette Posted June 18, 2006 Author Share Posted June 18, 2006 Does that mean you are willing to part with a set or are you just taunting me? Quote Link to comment Share on other sites More sharing options...
510six Posted June 19, 2006 Share Posted June 19, 2006 You know I just threw a set of them away when I grabbed the crank out of a core motor LD28.I`ll check and see if a friend can sourse a set. Quote Link to comment Share on other sites More sharing options...
Phyxius Posted June 26, 2006 Share Posted June 26, 2006 sorry to hijack....but i saw no use in starting a new thread titled the same thing... how do the diesel rods compare to the stock rods other than being longer? are they heavier/stronger or built about the same? Quote Link to comment Share on other sites More sharing options...
Mack Posted June 26, 2006 Share Posted June 26, 2006 deisel rods are 140MM center to center length. They weigh about 80 grams more than an L24 rod and they have a massive 25mm full floating pin. they look sturdy as all hell. Im sure they could take a LOT of boost. For use with normal pistons in a gas motor, I think you would have to bush the wrist pin hole to get it down to a normal size i.e. 21mm or so. Quote Link to comment Share on other sites More sharing options...
Phyxius Posted June 26, 2006 Share Posted June 26, 2006 the info on the engine builder utility must be wrong: it said they have a 21mm pin. I'm thinking of using those rods coupled with a piston with a smaller pin height (ie: rb26 or something similar.) with a standard L28 crank and block. If they are as sturdy as you say, a decent polishing job and shot peening should make them indestructible. Thanks for the info! Quote Link to comment Share on other sites More sharing options...
zaddict Posted June 27, 2006 Share Posted June 27, 2006 someone zcar.com just posted a classified ad for several parts from the diesel maxima engines- injection pump, intakes, etc. Quote Link to comment Share on other sites More sharing options...
