RIP260Z Posted June 19, 2006 Share Posted June 19, 2006 Hi, I brought a second hand LD28 crank from the States a few yrs ago, and it did not come with a front pulley bolt. When the engine parts were at the machine shop they informed me that a L28 front pulley bolt I supplied would not fit, due to the thread being wrong. I have looked again, and the thread on the crank looks fine (e.g. not cross threaded) , but the thread looks a bit rounded off. (Nothing wrong with the L28 bolt). I just wanted to check that the thread is 1.5 pitch, and the crank should accept a L28 pulley bolt, before I have the thread on the crank chased out. Cheers Ian Quote Link to comment Share on other sites More sharing options...
510six Posted June 19, 2006 Share Posted June 19, 2006 I just pulled a crank dampner of my LD28 cranked L30 stroker and it was a stock L28 dampner bolt, but I had to chase the threads after using a puller to get the dampner off. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted June 19, 2006 Share Posted June 19, 2006 I used a regular L28 crank bolt on my last LD28 crank. Quote Link to comment Share on other sites More sharing options...
greenmonster80 Posted June 19, 2006 Share Posted June 19, 2006 Run a tap and some WD-40 thru the hole. CLean it up a little..Suggestion. As I didn't need a special bolt for my crank Quote Link to comment Share on other sites More sharing options...
RIP260Z Posted June 20, 2006 Author Share Posted June 20, 2006 Thanks, I am about to run a tap through, but just wanted to check that the L28 bolt fitted. Quote Link to comment Share on other sites More sharing options...
