2802NR Posted June 19, 2006 Share Posted June 19, 2006 I f'd up my cable I got from DIY 'cause I think I was bending it too harsh through the fire wall. I straightend out the route but now I have to re-place it and I think $70 is a little steep for a cable so I was looking around and found a parralell female/female cable for $40 at: https://www.blackbox.com The entire cable is foil shielded instead of just the O2 wire and I think it is of higher quality than the DIY cable. do you guys think this will work or do you think it will cause problems with the o2 signal? Quote Link to comment Share on other sites More sharing options...
mobythevan Posted June 19, 2006 Share Posted June 19, 2006 I went and looked at it, it doesn't give a pinout. It will work as long as none of the signals cross over? Let us know if you get one. As long as you could return it if it doesn't have all the connections, then I would try it. Quote Link to comment Share on other sites More sharing options...
2802NR Posted June 19, 2006 Author Share Posted June 19, 2006 If its labled as "parralell" doesn't that mean no pins cross over? I thought that was the difference between parralell and series? It was my understanding that series is wired pin1 to pin2, pin2 to pin1 so both ends can send and receive data, where as parralell is wired pin1 to pin1, pin2 to pin2. Please correct me if I'm wrong, I'm still learning all of this. Quote Link to comment Share on other sites More sharing options...
mobythevan Posted June 19, 2006 Share Posted June 19, 2006 Not necesarrily, serial cables come in both fashions, cross over or straight through. Parallel AFAIK just means that there is more than 1 data line in the connector. A serial cable on has one data line and a parallel cable may have 12 or 16 data lines for example. Quote Link to comment Share on other sites More sharing options...
2802NR Posted June 19, 2006 Author Share Posted June 19, 2006 O.K., Thanks for straightening that out for me. Maybe I'll send them an e-mail and see if they have any info on the cable. Quote Link to comment Share on other sites More sharing options...
2802NR Posted June 19, 2006 Author Share Posted June 19, 2006 Here we go, I think this is what I'm looking for: try http://www.l-com.com/item.aspx?id=6939 It wont let me post a link for some reason Quote Link to comment Share on other sites More sharing options...
mobythevan Posted June 19, 2006 Share Posted June 19, 2006 yeah, that looks pretty good since they state it is a straight through cable. Quote Link to comment Share on other sites More sharing options...
Forrest Posted June 19, 2006 Share Posted June 19, 2006 Is 26 guage wire sufficient? Quote Link to comment Share on other sites More sharing options...
zguy36 Posted June 20, 2006 Share Posted June 20, 2006 Simply put, no! You run a lot more curent for driving injectors than a 26 gauge wire can handle. That is why the other cable is so expensive, since it has to be hand made with the larger wire. A computer application wire just wont hack it. Quote Link to comment Share on other sites More sharing options...
mobythevan Posted June 20, 2006 Share Posted June 20, 2006 here is the text from the manual: Quote For the wires from the DB37 connector to the sensors, injectors, etc., use 18 to 20 gauge for all the connections, then bring them to a common 14-12 gauge where appropriate. The only big wires are the ground and the two injector driver pairs, 32-33 and 34-35, all the rest can be 18 gauge all the way out. Quote Link to comment Share on other sites More sharing options...
badjuju Posted June 20, 2006 Share Posted June 20, 2006 Alls I knows is that Jerry over at DIY will bend over backwards to help a customer out and I've been happy with all the equipment I've bought from him. Lettuce know how it works out man Quote Link to comment Share on other sites More sharing options...
z-ya Posted June 20, 2006 Share Posted June 20, 2006 I would also worry about crosstalk between injector driver output wires and sensor wires because they are not shielded from each other. Infact, all the wires in the that cabe are shielded together. It could end up being a debug nighmare. I would either try to fix the one you have, or buy a new premade one. Quote Link to comment Share on other sites More sharing options...
