rdv88 Posted June 20, 2006 Share Posted June 20, 2006 I'm installing a 500 cid caddy engine w/ 400 turbo trans. i was wondering if any one knows how to make the motor mounts?? Any info would be greatly appreaicted. this motor is out of a '75 deville Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted June 20, 2006 Share Posted June 20, 2006 Welcome! I think you're on your own with it. As far as I know nobody has done this swap. If you do it, take lots of pics and post here!! Quote Link to comment Share on other sites More sharing options...
JustinOlson Posted June 20, 2006 Share Posted June 20, 2006 That will be a very cool swap I think. Do you know if you have to clearance the transmission tunnel for the th400? Regards, Justin Quote Link to comment Share on other sites More sharing options...
rdv88 Posted June 20, 2006 Author Share Posted June 20, 2006 I cut out the stock transmission mounts that sould be enough Quote Link to comment Share on other sites More sharing options...
dr_hunt Posted June 20, 2006 Share Posted June 20, 2006 Oh cool, finally a guinea pig of sorts. Quote Link to comment Share on other sites More sharing options...
TheNeedForZ Posted June 20, 2006 Share Posted June 20, 2006 I don't know if 500 and 472 caddy are the same or not, but a local guy pdinnel(also a member here) built a 472 caddy Z. http://forums.hybridz.org/showthread.php?t=101463&page=3 Quote Link to comment Share on other sites More sharing options...
JustinOlson Posted June 20, 2006 Share Posted June 20, 2006 Check out his gallery here: http://album.hybridz.org/showgallery.php?cat=500&ppuser=8191 Quote Link to comment Share on other sites More sharing options...
Z0wner Posted June 21, 2006 Share Posted June 21, 2006 record everything! Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted June 21, 2006 Share Posted June 21, 2006 this is what the mig welder,chop saw and scrap box are for.plus blocks of wood .caddy is probably a very overlooked engine and there is nothing more satisfying then a boatload of torque.now for that rare 3.31 r200 ring & pinion. Quote Link to comment Share on other sites More sharing options...
Z-Dreamer Posted June 21, 2006 Share Posted June 21, 2006 rdv88, Welcome! Paul Dinnell aka "pdinnell" a member here, has done it and while it is a tight fit, it can be done! Mark Quote Link to comment Share on other sites More sharing options...
Z-Dreamer Posted June 21, 2006 Share Posted June 21, 2006 I don't know if 500 and 472 caddy are the same or not' date=' but a local guy pdinnel(also a member here) built a 472 caddy Z. http://forums.hybridz.org/showthread.php?t=101463&page=3 Size wise, a 472 and 500 are the same, only difference being the stroke and head camber sizes, 76 or 120cc. Mark Quote Link to comment Share on other sites More sharing options...
jbk240z Posted June 21, 2006 Share Posted June 21, 2006 There is a member on here, stampie is his sig. in progress 500 caddy swap. http://www.stampie.com Quote Link to comment Share on other sites More sharing options...
TheNeedForZ Posted June 21, 2006 Share Posted June 21, 2006 Size wise' date=' a 472 and 500 are the same, only difference being the stroke and head camber sizes, 76 or 120cc. Mark[/quote'] Oh, I should have been clearer, I was referring to engine mounting position of the two blocks. But it's not like I know anything about caddies. Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted June 21, 2006 Share Posted June 21, 2006 Well cool, I didn't know someone on this site already did this swap! Quote Link to comment Share on other sites More sharing options...
Z-Dreamer Posted June 21, 2006 Share Posted June 21, 2006 Oh, I should have been clearer, I was referring to engine mounting position of the two blocks. But it's not like I know anything about caddies. The engine blocks are virtually the same, so the engine mounting position or location is the same. Mark Quote Link to comment Share on other sites More sharing options...
Guest Mike Posted September 9, 2006 Share Posted September 9, 2006 Are you going for it? I'm considering the same swap. My SBC 350 may be toast... don't know yet. If so, the Caddy 500 may be the way I want to go. My SBC currently has the Scarab style mounting kit but I just bought a JTR kit. Any idea how much of this I can use? Am I starting from scratch? Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted September 10, 2006 Share Posted September 10, 2006 -------------------------------------------------------------------------------- http://forums.hybridz.org/showthread.php?t=101463 you should read thru this thread first, and Id sure try to find a donor 1970-73 eldorado or similar car with with a 500 caddy if you can (preferably with rear drive) btw the 472 and 500 caddys have the same outside dimensions only the stroke, heads, and internals differ __________________ Quote Link to comment Share on other sites More sharing options...
Challenger Posted September 10, 2006 Share Posted September 10, 2006 Wouldnt a 500 caddy be way to heavy to put in a Z? I'm guessing your not going for autocross more a drag car? From what I know does a front heavy car make it understeer in the corners? Might not be a good autoX car but I bet itll fly in the quarter mile!! Good luck Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted September 10, 2006 Share Posted September 10, 2006 500 caddy Cadillac V8 472-500 625lb with aluminum intake your down to about 605lbs 350 chevy Chevy small block V8 575 (generic for '60s-'70s motors) Chevy small block V8 535 (1) ('59 Corvette 283 w/alum. intake) Chevy big block V8 685 Mark IV (all iron) you can drop 80 lbs to about 605 lbs with aluminum heads,intake and water pump theres not enought differance to worry about at about 30-100 lbs (depends on config) the distributor on the caddys in the front so it can be seated several inches more to the rear in the engine compartment, weight distribution might even be better Quote Link to comment Share on other sites More sharing options...
Challenger Posted September 10, 2006 Share Posted September 10, 2006 Whats a l28's weight? Quote Link to comment Share on other sites More sharing options...
