Guest MAG Posted June 22, 2006 Share Posted June 22, 2006 Hi I think this isn't a big deal but I just want to make sure and it would be nice to fix. When I turn my turning signals on the fuel pump in the back of my 280z seems to sound diffrent (almost like an oscillating sound from a voltage change). So I'm wondering is this a big deal? Won't this affect the way the fuel is pumped into the motor? Also if this is a concern how should I go about fixing this problem. Thanks. -MAG Quote Link to comment Share on other sites More sharing options...
Twizted Posted June 22, 2006 Share Posted June 22, 2006 Direct wiring via a relay will fix voltage problems to your fuel pump. But have you actually tested the fuel pressure both off and under a load? Noises do give you an alert but I had my factory pump running louder than my radio with no problems with fuel supply. I don't know how or why but it was. I finally changed it for a new factory pump due to be sick of hearing it but still no change in fuel supply. And that's still using factory wiring to the pump. Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted June 22, 2006 Share Posted June 22, 2006 Clean your battery posts. Sounds so simple, my guess is you will go for the more complicated fix instead. But trust me. Clean your battery posts. Quote Link to comment Share on other sites More sharing options...
