blue_leaf Posted July 2, 2006 Share Posted July 2, 2006 Just curious what exhaust manifold people are using, so post up your pics... Interested in manifolds for all engines - just wanna see different designs... :) Quote Link to comment Share on other sites More sharing options...
slownrusty Posted July 2, 2006 Share Posted July 2, 2006 OK I'll play.... 1) Stock Manifold with a 46mm HKS welded on....bought from Dave P....this manifold with the WG weighs 24lbs 2) SFP (South Florida Performance) manifold I bought 4years ago (!!) and kept in a box with a bunch of friendly spiders watchdogging ...external WG pipe and flange to be welded in this week and I will be running a 38mm TiAL WG...weight about half of the stock manifold. Yes I will have to send it back to be JetCoated! Yasin Quote Link to comment Share on other sites More sharing options...
blue_leaf Posted July 3, 2006 Author Share Posted July 3, 2006 Any more pics... I would have imagined tha more people here have custom/aftermarket manifolds? Quote Link to comment Share on other sites More sharing options...
slownrusty Posted July 3, 2006 Share Posted July 3, 2006 Surprisingly nope....guys making big power usually use the stock cast manifold which apparently is good to 400+. The aftermarket turbo manifolds are few and far between and usually one off custom pieces that require big $$ to fabricate. There is actually a guy in Australia (he is on this board - forget his name) with a beautiful Medusa looking thing..because you guys have RHD drive allowed an intricate tube set-up and not having to worry with the brake boosterlinesmastersteering linkage cylinder in the way. Mike on3go also has a sexxy piece that he has, that will have to be modified to fit the LHD Z cars...this is what his manifold looks like (I am sure he does not mind me posting the pics): Yasin Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted July 3, 2006 Share Posted July 3, 2006 yep thats mine. ill have to take some pics of how it is now, and once i get the turbo it will be showed on the car, mike Quote Link to comment Share on other sites More sharing options...
TimZ Posted July 4, 2006 Share Posted July 4, 2006 I just had my SFP mainfold modified by Speedshop Thagard. Stainless steel slipjoints were welded in in the three main stress points for expansion/contraction. This should eliminate the warping/cracking problems that were associated with this manifold. Price was reasonable, too... Also, here's how I handled the bracing for the GT42R that is going to be mounted to it: Quote Link to comment Share on other sites More sharing options...
greenmonster80 Posted July 4, 2006 Share Posted July 4, 2006 Here is mine. I know it fits a RHD would like to check it against a LHD car. Turbine is a TD07 and wastegate is a Trust model..Pic is too big to attach so here is the link for gallery http://album.hybridz.org/showphoto.php?photo=2978&cat=500&ppuser=9707 I think with the turbine being as low as it is piping should be easier to fit.. Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted July 5, 2006 Share Posted July 5, 2006 I continue to be amazed that folks think they need those incredibly complex and fragile bundle of snakes while "poor Tim" is "making do" with 600hp and that apparently simple manifold . I have similar sentiments about DPs but I wont go there. Quote Link to comment Share on other sites More sharing options...
TimZ Posted July 5, 2006 Share Posted July 5, 2006 I continue to be amazed that folks think they need those incredibly complex and fragile bundle of snakes while "poor Tim" is "making do" with 600hp and that apparently simple manifold . I have similar sentiments about DPs but I wont go there. Quote Link to comment Share on other sites More sharing options...
spork Posted July 5, 2006 Share Posted July 5, 2006 I have a very ugly exhaust manifold that I made with nothing other than some weld els and a mig welder. No dyno graphs for horsepaower, but my 131mph trap speeds mean I should be around 600hp at the crank. The long runner exhaust manifolds are cool, but they take up a lot of space, loose a lot of heat, no matter how well they are thermal coated, and can be a "can of worms" so I'm with scottie and Tim on this one. I think I had $150 or so in my manifold, and it shows, but works awesome. If you do some searching, you can find pictures of it. It will soon be replaced by one of much higher quality that I'm building but will still be fairly simple in design. I like to keep the heat in the manifold, rather than transferring it into the engine bay and my intake manifold. Quote Link to comment Share on other sites More sharing options...
240hoke Posted July 5, 2006 Share Posted July 5, 2006 Slightly modified stock manifold, external gate and some mild porting. Hoping it will take me to at least 450hp. Ive trapped 125mph@16psi so far. Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted July 5, 2006 Share Posted July 5, 2006 I continue to be amazed that folks think they need those incredibly complex and fragile bundle of snakes while "poor Tim" is "making do" with 600hp and that apparently simple manifold . I have similar sentiments about DPs but I wont go there. i would love something like Tim's.. but i never once found one forsale and i just dont have the tools as of yet to make my own. i bought mine for a amazing deal.. cant beat it. mike Quote Link to comment Share on other sites More sharing options...
