240playtoy Posted July 2, 2006 Share Posted July 2, 2006 A good while ago I swapped my brakes to front toyota 4x4 calipers and 240sx calipers w/ appropriate disks. Also added the 280zx MC. After excessive brake bleeding, I hunted down the fact that my reaction disk fell out in my old booster (thread) and replacing with a new booster, my pedal would drop 3-5" before any resistance. I heard a lot of hissing coming from the booster area. Hours of searching later, I found that several people had had bad rebuilt MC's and they made hissing noises. So I purchased a $30-$40 rebuilt MC for replacement from Autozone (lifetime warrantee for insurance against crappy rebuilds). More searching later, found some people had adjusted the actuating rod (between booster and MC). I check mine out before going thru the trouble of removing and replacing my "defective" MC. Measured up my old MC plunger depth and the 280zx depth. This is what I found. As was done by others, I had to adjust my rod. My hissing is gone and the pedal is rock hard and has <1" of travel before engaging. Evidently my excessive bleeding of my brakes had removed all the bubbles. Time to license my car!! Quote Link to comment Share on other sites More sharing options...
J__ Posted July 11, 2006 Share Posted July 11, 2006 how do u adjust the rod? is it a screw that adjusts it? i have to do the same thing when i swap my mc Quote Link to comment Share on other sites More sharing options...
240playtoy Posted July 12, 2006 Author Share Posted July 12, 2006 there's a piece similar to an acorn nut on the end that threads into the rod. I believe it needs a 7mm wrench. I held the shaft with needle nose pliers and loosened the treaded rod. After it was loosened, you can thread it out with your fingers. Quote Link to comment Share on other sites More sharing options...
J__ Posted July 12, 2006 Share Posted July 12, 2006 sweet. thnx for the info Quote Link to comment Share on other sites More sharing options...
