datman Posted July 11, 2006 Share Posted July 11, 2006 Hi Guys Here are some pics of the struts I have had made for my 240. They are shorter than standard with fully adjustable custom made inserts. The hubs had the original bored out and new tubes fabricated with thread on the outside. Just got to weld the tubes inot the hubs now Quote Link to comment Share on other sites More sharing options...
mark Posted July 11, 2006 Share Posted July 11, 2006 That looks like a great idea. Any info on what you used for the tubes? Quote Link to comment Share on other sites More sharing options...
datman Posted July 12, 2006 Author Share Posted July 12, 2006 It was just regular steel tube, machined to shape with a thread cut on the outside, a small disc welded on the bottom and a nut made to go in the top to hold the dampers secure. I'm thinking I'll get the next set made in stainless. Do you think there would be enough interest so sell a few sets? not for profit just to cover costs Quote Link to comment Share on other sites More sharing options...
mark Posted July 12, 2006 Share Posted July 12, 2006 All depends on the cost. Any idea on that? Quote Link to comment Share on other sites More sharing options...
johnc Posted July 12, 2006 Share Posted July 12, 2006 Make sure your new strut slides down into the hole in the hub casting and is not just butt welded to the top of the original strut mounting. Weld it at the bottom and where it meets the casting. I built something similar when I ran the Penskes on the ROD and a we tested, with a hydraulic press, a couple different ways of mounting the strut tube to the hub casting. Butt welding the strut tube to the casting failed. Quote Link to comment Share on other sites More sharing options...
datman Posted July 12, 2006 Author Share Posted July 12, 2006 Yeah will do, if you look at the strut it has been machined down to fit all the way down in the hub, it will then be welded (properly). There will be no chance of it falling out. The guy who is making them makes some serious stuff, these are like scrap metal toys to him! Quote Link to comment Share on other sites More sharing options...
datman Posted July 12, 2006 Author Share Posted July 12, 2006 Mark, I can get you a cost Friday as thats when I get the bill. I would imagine he will charge me somewhere near £180 so times that by 1.7 for a rough dollar cost. Quote Link to comment Share on other sites More sharing options...
datman Posted July 15, 2006 Author Share Posted July 15, 2006 http://www.zclub.net/forum/showthread.php?t=7340&highlight=struts finished pictures here cost £300 Quote Link to comment Share on other sites More sharing options...
fastzcars Posted July 15, 2006 Share Posted July 15, 2006 It looks great! as far as adjustment, I only see one at the top? Does it adjust compression or rebound? Does it have to be disassembled to adjust either or? How about the internal parts, are they all custom as well? A couple of pix of the internals would be great! I would diffenetlly make them in stainless! What was the final cost? Quote Link to comment Share on other sites More sharing options...
datman Posted July 16, 2006 Author Share Posted July 16, 2006 Hi Yes the adjustment is made from the top (hex nut) only rebound, bump is fixed although this guy also makes double adjustables. All valving is custom, I hade the shock bodies machined to the length i wanted and they made the internals to suit. I will get some pics of the internals. The guy that made them was the original owner of AVO shocks. adjustment is easy, they give you a plastic thing that sits on the hex nut and you turn it to adjust, can be done from under the bonnet (hood) I asked for compression to suit my 250lb springs, they usually set it for much higher as they mainly make race shocks. International shipping is no problem Quote Link to comment Share on other sites More sharing options...
datman Posted July 16, 2006 Author Share Posted July 16, 2006 Total cost for all 4 shocks and struts including materials is $1200 so far, oh and $140 for springs Quote Link to comment Share on other sites More sharing options...
