need quick help with clutch question
Guest dan4011
Guest dan4011
i have to place an order for a clutch tonight, i am about to be putting a turbo'd n/a 280z motor in my 76 with a 280zx turbo flywheel, i need to know if i need to specifically get a turbo clutch or if the 2+2 clutch will also work.
im kinda confused, also im looking at the centerforce 1 clutch, wheres a good place to get them cheap?
thanks alot guys, any help is greatly apreciated
I have not heard many things about Centerforce 1 or 2 clutches being bad. Just the dual friction discs going out. I was about to get the Spec flywheel and ACT pressure plate and full disc. I just went with all spec stuff in the end. 750 miles on the Spec stage 2+ and it still looks pretty good now that the motor is out. I am just using the 225mm stuff and the stage 2+ is rated good up to 265 horsepower. It is just a hair stiffer than my stock clutch but very firm and crisp engagement. It was a it pricey though and I paid full price because I needed it ASAP before a show/drive.
god luck on your endeavor!
