car nearly finished
First link doesn't work if you're not a member.
Comment on the 2nd one. I watched the video and you could hear the wheel scraping, but you couldn't tell on what. There was also some mention of the holes being misaligned. Holes misaligned is pretty bad and I'm glad to hear the wheel manufacturer seems to be standing behind his product, but as far as the grinding I'd be marking the stub axle and the outer edge of the rim and turning the wheel around and seeing where it grinds. If it grinds on the same place relative to the stub axle then it could be bent. Not terribly uncommon for someone to get in a very minor collision and bend a stub axle. Grinding on the same place on the wheel would tend to indicate a bent wheel.
yes i tried different wheels on the same hub and they were fine. seems the holes are slightly off centre.
Here is the picture of the car that you couldn't see
how do you get the pictures to appear full size in the message window?
