slownrusty Posted August 6, 2006 Share Posted August 6, 2006 Gang - I have two questions (I have a E6X). 1) Where do you source sensors, I am looking for a new air temp and O2 sensor, plus my Haltech did not come with the Fuse Block Assembly...where do I got one of those? Also one of my injector clip that plugs to the top of the injector was missing when I got mine, so I need one of those bad boys too. 2) All the extra harness (and there appears to be alot!) that you did not use...did you just curl it up and hide it out of the way..or did you try and remove it to make it neat? Thanks in adavance. Yasin Quote Link to comment Share on other sites More sharing options...
Sparky Posted August 6, 2006 Share Posted August 6, 2006 Quote Gang - I have two questions (I have a E6X). 1) Where do you source sensors' date=' I am looking for a new air temp and O2 sensor, plus my Haltech did not come with the Fuse Block Assembly...where do I got one of those? Also one of my injector clip that plugs to the top of the injector was missing when I got mine, so I need one of those bad boys too. 2) All the extra harness (and there appears to be alot!) that you did not use...did you just curl it up and hide it out of the way..or did you try and remove it to make it neat? Thanks in adavance. Yasin[/quote'] it uses standard GM sensors. but dont have the part numbers with me... The fuse block is a standard ATC four fuse block, the kind that you can buy at autozone and snap together. I curled all the extra wiring up behind the dash just in case i wanted to transfer the haltech to a different car in the next few years. I just finished wiring the injectors and distributer about ten minutes ago...all I have left is the ignition module and It should be good to go Quote Link to comment Share on other sites More sharing options...
slownrusty Posted August 7, 2006 Author Share Posted August 7, 2006 Sparky - Which GM vehicle should I say I need those sensors as the local parts stores do everything by year, make, model and the guys behind the counters are well....not the most helpful. Thanks Yasin Quote Link to comment Share on other sites More sharing options...
Sparky Posted August 11, 2006 Share Posted August 11, 2006 I've already PM'd this to you but here it is out in public just in case others need the info: Coolant temperature sensor (CLT) GM #12146312(may have been replaced by #15326386) Standard TX3 GP SORENSEN TSU81 AC DELCO 213-928 NIEHOFF DR134AK WELLS SU109 MSD 2310 (includes connector) Air temperature sensor (IAT) GM #25036751 Standard AX1 GP SORENSEN 779-19001 AC DELCO 213-190 NIEHOFF IGNITION TS83631 was DR-136W WELLS SU107 MSD 2320 (includes connector) more information than you could ever want about these sensors: http://www.megasquirt.info/manual/mwire.htm#clt Quote Link to comment Share on other sites More sharing options...
