Alternate sources for 240Z inner tie rod ends
I've had zero luck in finding a source for inner tie rod ends for my '73 240. Pep Boys, Advance, Parts America, Autozone, NAPA, Carquest - you name it - all have the wrong part referenced - ES2277L, among other numbers used. Nissan has them, but you have to buy the inner and outer as a unit, and the cost is $175/side. Aftermarket prices for the inner tie rod run in the $20-40 range, if only they could source the right part. Anyone have sources or suggestions for non-Nissan replacement parts? Yes, I know Nissan has the best stuff, but the cost is just silly in my mind. Thanks for any input!
Not quite in your price range but check this....
http://www.sfxperformance.com/parts/MOOEV164.htm
Another source is to call Summit because they carry this....
http://store.summitracing.com/egnsearch.asp?SearchType=Make&N=700+4294907666+4294902027+4294925074+4294925130+115+4294839070&NeXID=5
LARRY
I think he's looking for the "inner" tie rods... those are the outer
If you read the description it may be the correct item? (Rack end) maybe its a "stock" picture??????????????
Are you looking for ITEM #9 from the diag. below?
[ Moog Parts ] Fitment Guide
1970-1978 Datsun/Nissan 240Z/260Z/280Z
Description
Moog EV164
Moog Inner Tie Rod Ends are heavy duty OEM replacements complete with rubber tie rod boots.
RIGHT - INCLUDES BELLOWS
2 required per vehicle.
Special order please allow two weeks for delivery
