Any ones Brake hoses rub on Tires? How to handle?
And if a full turn is too much, then loosen the hose-to-line fitting and re-clock the hose end so that the hose is lightly twisted out of the way. Yes, you'll need to bleed the brakes when you do this, but it will prevent the hose from being twisted too much.
This is on the assumption that you've got a non-OEM setup?
