trwebb26 Posted August 16, 2006 Share Posted August 16, 2006 When assembling a v3.0 board with the plans of using an MSD box for ignition - do you use hall/opto wiring (step 50a) or "trigger off of the negative terminal" (step 50b)? http://www.megamanual.com/ms2/V3assemble.htm#input I ordered my megasquir pre-made and I'm not sure if they wired it correctly for my application. Quote Link to comment Share on other sites More sharing options...
z-ya Posted August 16, 2006 Share Posted August 16, 2006 So you plan on driving the MSD with the distributor, and then triggering the MS off the MSD? You want to drive the MS with the MSD tach ouput. I would lean towards the negative coil trigger configuration. Quote Link to comment Share on other sites More sharing options...
trwebb26 Posted August 16, 2006 Author Share Posted August 16, 2006 But is says that you can't control ignition if you use that method (configuration 50b). I'm thinking that the only correct way is by configuration 50a (optically). My problem is that I expect it to have been wired by the 50a configuration - but my board has the 50b.... ??? Quote Link to comment Share on other sites More sharing options...
Forrest Posted August 16, 2006 Share Posted August 16, 2006 Whether or not you use optical/hall or VR is your choice for the input of the tach signal. You could use MSD as the output for either input. You need to specify which input you want to use. Either way, don't worry - it's very easy to change those jumpered settings. Quote Link to comment Share on other sites More sharing options...
trwebb26 Posted August 16, 2006 Author Share Posted August 16, 2006 If I understand it correctly - there are three choices for input... #1) Hall/Optical that takes the square wave input from a Hall sensor, optical sensor, or points (installation 50a in the manual) #2) triggering off the coil - but only if you are not controlling ignition timing (installation 50b in the manual) #3) VR takes the AC signal from a variable reluctor sensor and converts it to a square wave for use by MegaSquirt (installation 51 in the manual). I'm trying to decide if I should be using option #1 or option #2 Quote Link to comment Share on other sites More sharing options...
