Custom Fuel Rail advantages
Guest Andrew240
Guest Andrew240
What are the adavantages to a custom fuel rail? At what point does one find the stock L28et fuel rail inadequate? I plan on running SDS, and was wondering about the whole fuel rail issue.
Thanks!
There might be something to the claims that there is less chance of vapor lock - I think you have to live in the desert to run into problems with the stock rail. The biggest advantage is that it makes maintenance 100x easier.
I got so frustrated with the last stock rail I was trying to take out, I ended up cutting it up with tree clippers. I've had to replace fuel pressure regulator on my 77 before I put a new rail in, and after about 40 minutes it made me want to scream trying to get that hose back in place. I'm a reasonably patient person when working on my cars, too. It just gets ridiculous.
Replacing an injector or the FPR, or taking them all out to clean them, etc, takes a few minutes minutes with an aftermarket rail.
Plus they look cool. :)
I bought all 3 of mine from Pete: http://www.freewebs.com/pallnet/
Most people upgrade for one of 3 reasons. They're upgrading injectors to an o-ring style injector, they hate pulling the stock rail off, or they want to clean up the engine bay and make it look a lot simpler and dress things up a bit. Or any combination of the 3. We make custom fuel rails as well if you're interested. As far as an actual need for a new rail when using the stock injectors, there is no need...just want. The stock rail will support a moderate turbo build or a very extreme N/A build without a problem.
Most people upgrade for one of 3 reasons. They're upgrading injectors to an o-ring style injector, they hate pulling the stock rail off, or they want to clean up the engine bay and make it look a lot simpler and dress things up a bit....
I have a stock 81 280zx Turbo...and aquired a fuel rail recently. Here is the question; is it good practice to replace the STOCK fuel regulator when using a fuel rail? OR-can I use the stock regulator?
