Guest Mpower280 Posted August 21, 2006 Share Posted August 21, 2006 I have a 60mm TB from a 91-93 240sx, Spacer, 280cc Injectors from a 350Z, and an O-ring fuel. How do I make this work? Quote Link to comment Share on other sites More sharing options...
veritech-z Posted August 21, 2006 Share Posted August 21, 2006 What are you doing for fuel management? The throttle body will just bolt on, but if you want it to work better you have to port match the manifold to the new diameter. You can mix and match the throttle linkage parts to get your original z linkage to work. Quote Link to comment Share on other sites More sharing options...
mario_82_ZXT Posted August 22, 2006 Share Posted August 22, 2006 Wow 350z injectors are small! Are they top or side feed? O-ring or barbed? Still not much of an improvement over stock turbo injectors. Mario Quote Link to comment Share on other sites More sharing options...
slownrusty Posted August 22, 2006 Share Posted August 22, 2006 I have a 60mm TB from a 91-93 240sx, Spacer, 280cc Injectors from a 350Z, and an O-ring fuel. How do I make this work? How will you make it work? Easy.... By going stand alone engine management. Quote Link to comment Share on other sites More sharing options...
