manual trannies
The T-5 is an excellent choice for a V8 Z car. Depending on the torque of your engine you may want to consider using a “World Class†(WC) version which is a bit beefier. Some Camaro versions tilt the trans over at a 14 degree angle. You can use a 1984 and later Corvette bellhousing to "straighten" the trans up. A plus to using the Corvette bellhousing is that it has a much better hydraulic slave cylinder. You will have to make a wedge shaped adapter or slightly change the design of the transmission mount as well.
Using the JTR conversion method you will find that the T-5 shift lever ends up right where the old Z car shifter was.
For obvious reasons I wanted the look of the tall shifter but it has quite a long throw. You may want to consider a shorter shift level and/or short throw shift kit.
