porche brakes on 240?
Guest Anonymous
Guest Anonymous
I quickly picked up a mag called impot racer with a 500hp stright 6 and it had a 930? twin turbo brakes up front. any body here of this?
Yes, that car was also at the MSA Natl's. Looks great....but how much does it cost? For the conversion bracket, and then for the parts alone? It's great, looks custom, is impressive, but too rich for my blood. That guy has big bucks to build cars like that.
Davy
porsche brake if they are the "RED" ones are just brembo street calipers. cost more to say porsche on em.. are they a upgrade from wilwood/outlaws? not sure ??.... and will cost 2x - 3x as much USED.. the porsche calipers are not the REAL race brembos...
i'll stick with outlaws and if i win the lottery (which i wont as i dont often buy tix) i 'll opt for the top line brembos...
Guest Anonymous
thanks for the insight on brakes I haven't priced them out (still looking for a decent Z car)
I also saw a custom AWD civic with Z struts and it said vette brakes ever heard of this?
Again, I'm sure anything can be done, but it comes down to time and lots of money. I try to stay away from even looking at Hondas, because I really don't like them. When my car is finished, Hondas will be my whipping boy.
Davy
Hrm, SCCA would your brackets work? Spacing the same as the Outlaw stuff? I've got the Outlaw calipers guys, they're NICE and I'm not sure they're all that expensive comnpared to those Porsche calipers. Is that $259 price for new ones? icon_confused.gif
porsche big red are not a normal bolt on they use bolts vertically AIR not horizontal in the mouting plane so a PITA to mount..
and as i said before these are NOT the real good brembos.. they are a cheaper one and i think they are more with the porsche name on them a-- i'd prefer it to say brembo .
SCCA, not to dispute your argument that the Porshe brakes in question are not real Brembos, but it cannot be disputed that 911s have some of the best brakes in the world.
Every time I go from my 911 brakes to my Z brakes I can only wish I had them in my Z and my Z has late ZX calipers/300 ZX rotors in front and full late ZX brakes in the rear with KVR pads. I will, however, definitely agree with you that it is not worth the hassle and you are better off getting a set of your Outlaws.
Guest Anonymous
Porsche brake swaps are very popular in the German car community... A friend of mine has the "little Reds" (Boxster S) on his Audi A4. The brackets that attach the caliper to the knuckle have bolts that go in horizontally... Might not be as hard as we think...
Hrm, the only advantage that I think "we" might see with this is maybe dust seals. Outlaw and Wilwood don't have dust seals I'm told but I've also been told the seals don't do much anyway (shrug). IMO the Outlaws are probably just as good if not better and cheaper too by about $100 a corner.
Scottie - if you want better brakes look at Mike's 12+inch Outlaws icon_smile.gif I'll let you know how they work here soon enough but I fully expect that they will be as good as the brakes on my Mustang. As big as they are and with as little weight as the carries it should be interesting!
the porshce reds are real brembos made by brembo for porsche.
while they are better than "most" oem stuff they are not the "real" brembos that Brembo sells as off the shelf. Brembo makes a LOT of OEM stuff, cheaper castings , less material - not as stiff etc... i am no Brembo expert (a friend is) and from what i gather there are many different levels of brembos from cheap to $$ to $$$$...
and BLKMGK is correct the only advantage is dust seals (if that is a advantage for the amount our cars get driven) also i dont know it the "reds" have stainless pistons or not?
FYI a full seal kit for a wilwood or outlaw is only like $12 per caliper so if you changed it every 2-3 years its not gonna break the bank!
and Scotty- 911's do have great brakes (for stock) but on the track they arent big enough!.. my "little 200sx" can outcorner a 911 and outbrake it. its just the HP where the 911 will pull away.. and it should.
