78zlt1 Posted December 31, 2006 Share Posted December 31, 2006 That may work, It really comes down to what you feel is safe for you and your passengers. Box tube is stronger than channel , and I'm by no means an expert in chassis construction. take pictures and post your progress. Quote Link to comment Share on other sites More sharing options...
gvincent Posted January 2, 2007 Author Share Posted January 2, 2007 Thanks, for the response, I am getting a quote to have both your mount with my modifications and the rear diff mount made as well. The two end pieces I will have made out of "U" channel of the same size as your box, weld the bolt plates to it and then cut and grind to match the floor contour and mate up to the sub frame rails which are already beffier than stock. Onec it is all fitted I will weld to the sub frame AND the floor. Either way I believe it is much stronger than bolting a stamped piece of flat stock through the floor! I will post pics once the pieces are built. Thanks, Greg Quote Link to comment Share on other sites More sharing options...
