installing plugs can be a P.I.T.A.
there are several tricks & tools that make installing plugs easier, one trick to installing/starting the threads is to slip a plug neck firmly into a 18" section of fuel line, this allows the plug to be easily dirrected into place,spun and aligned in a tight place .
gap them correctly, a .043 is about correct for most applications and don,t forget the ANTISEEZE on the threads
cutting a standard socket to shorter length helps at times
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=94011
http://www.rshongkong.com/cgi-bin/bv/rswww/searchBrowseAction.do?com.broadvision.session.new=Yes&D=Sidewinder%20Speedwrench&Ntt=Sidewinder%20Speedwrench&Ntk=I18NAll&Ntx=mode%20matchany&N=0&Nty=1&name=SiteStandard&forwardingPage=line&R=2483097&callingPage=/jsp/search/search.jsp&BV_SessionID=@@@@0140285926.1159188189@@@@&BV_EngineID=cccjaddilkjdlmmcefeceefdffhdhif.0&cacheID=hk01netscape&Nr=avl:hk01
http://www.mytoolstore.com/kd/kdgear02.html#9520
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=91705
