A question for Haltech Users
wecvusmc
I am installing a e11v2 in my 76 turbo swap. I have installed the wiring and I am ready to start setting up my ECU, but I can't connect to it. I have done the basic checks such as making sure the ECU has power and com ports are set on the correct settings. I am using a serial to usb adapter that I know works because it works without a hitch with my wideband (com port 1). The wideband is getting power from the ECU. I have the settings in halwin set to com port one and the usb serial adapter to com port one. I have also tried three other com ports (2-4) with no avail. I have also tried using a friends computer but that doesn't work either. Am i missing something here? Or is it possible that I have somehow gotten a bad ECU. Thanks for your input.
