solid engine mounts?
81280zx
Solid engine mounts are only for a race car, something that is never driven on the street and always driven wearing a helmet. The advantages are:
1. One less point of failure.
2. Handling improvements, car transitions better because the mass of the engine isn't moving opposite of the chassis.
3. Engiune can be moved back, down, and closer to other things because it will move much less.
4. Slight structural improvements.
The disadvantages are:
1. Vibration.
2. Vastly increased vehicle inspection and maintenance because of the vibration - nuts and bolts all over the car loosen up, electrical parts break, parts fall off, hoses need to be protected from chafing, radiators need to be rubber mounted, exhaust system mounts need to changed.
3. Noise.
4. Transmission has to be solidly mounted also.
SHAKE, RATTLE, and ROLL!!! :mrgreen:
  81280zx said:
Hey all i found some solid engine mounts and i wanted to know what the benifits would be and the disadvantages of this moount or should i stay with the rubber style
