Starting a Stored LT1 Engine
Hi everybody it has been a long time!
I have a perfect LT1 engine that has sat (stored) for 5 years in my shop. With an older gen1 350 the normal procedure would be to prime the engine with oil by removing the distributor and using an electric drill and a adaptor. On the LT1 and LS1 models there is no shaft type distributor system so how does one prime these Gen11 and newer engines? The last thing I want to do is damage any bearings!!!!!
I thought and I know it would be some work would be to remove the oil pain and lossen all the main and rod caps and TRY and get some fresh oil under them and then torque everything back up.
Other Suggestions?
Danno74Z
You can prime the LT1 in a similar way, but I think the intake has to be removed to remove the dummy distibutor shaft and get your power drill/screwdriver in there and turn the pump. I think it actually turns with a large flatblade type screwdriver tip.
I can look it up in my manual if you need more info, I did it when I rebuilt my top end.
