Rear Bumper Removal
Mr.INSANE
Yep, undoing the straps on the gas tank and supporting it with a jack to be able to move it up/down and side to side will let you squeeze in there and remove either the 3 or 4 bolts per side.
I depressurized mine then cut them with a sawzall then unscrewed them.
It's kinda a pain...
Mario
My gas tank and exhaust were completely removed when I took the "shocks" out. You can get them through the body without cutting them if you have enough room to wiggle them around.
Each of the shocks on my '76 was held on with 2 bolts and 2 nuts. The bolts toward the center of the car are removed from beneath. The nuts are removed from inside... they are hiding behind the rear side trim panels.
