New Wheels not fitting
i picked up 4 american racing wheels wraped in uniroyal tires today.. they were a good score so i thought id try them on my Z
Well they don't fit icon_mad.gif the 225/50/15 tires hit the springs... are the wheels and tires just to big, or is there anything i can do..
thanks alot..
Jonathan
You can get spacers made up but the bolt ons are better. If you decide to ditch the rims let me know or if another good deal falls upon you let me know. It just sounds like a little help on the back spacing is all, how close are they to fitting?? icon_confused.gif
225-50-15s should fit with the right backspacing wheel... Which means you got yourself some tires. Unfortunately the backspacing on that wheel is your problem. On an 8inch wide wheel the ideal backspacing should be 4 inches, or zero offset as some refer to it. Zcars work much better with a zero offset wheel, so keep that in mind the next time you go to purchase wheels. You can get spacers for your ride, but that may require upgrading to longer wheel studs as well.
Mike kelly
ZF Racing Products LLC
" On an 8inch wide wheel the ideal backspacing should be 4 inches, or zero offset as some refer to it."
Just to be clear for others, Mike means a 7" width wheel which is typically 8" overall (ie. outside lip to outside lip) when he says 4" backspacing/zero offset etc.
If you use bolt on wheel spacers then longer studs shouldn't be needed, although you should be sure the condition of current studs is good. If the required spacers are quite thin (ie. <1") then slipons and long studs can be a lot easier. I hope to have some pricing for the wheel spacers up on my site by the end of the wknd.
