gretchen/jason Posted October 22, 2006 Share Posted October 22, 2006 Is there anyway to slow down the watter pump itself as to get the watter to flow the same speed at 3 grand as it does at idle in other words slow it down quite a bit ive tried restrictor plates but not much luck . The watter flows to fast at speed to cool off enough as i can never get the t stat to seal like it should and ive tried everything even ordered a new neck from chevy and t stat sealed it with silicone and such still no luck . When i leave in the morn if i turn on the fan it takes 10 miles for the temp to hit 180 turn it off and about 2 miles of driving . Quote Link to comment Share on other sites More sharing options...
Forces Posted October 23, 2006 Share Posted October 23, 2006 you could try a larger diameter pulley on the water pump, but I don't know effective that would really be. you could also go with an electric water pump. Quote Link to comment Share on other sites More sharing options...
specialk Posted October 26, 2006 Share Posted October 26, 2006 It's a common myth that water flowing too fast will not cool your engine well. Look at it this way, if 5 gallons goes through the radiator in 1 minute, cooling by 10 degrees, that same 5 gallons going through 30 seconds will cool 5 degrees. But, in one minute, it will have passed through twice (losing the other 5 degrees) for the same effective cooling rate. So, please banish that thought. To your other problem, if you can't get the t-stat to seal, there must be something wrong with: A) the intake manifold the water neck C) the thermostat Be sure that the first two are perfectly flat and (IIRC) that the t-stat fits down into the recessed area of the intake correctly. Quote Link to comment Share on other sites More sharing options...
