Guest GM-7 Rocket Posted October 25, 2006 Share Posted October 25, 2006 I'm in the prosses of changing mt T-5 for a T-56 in my 84 RX-7 but I ran in to the problem of not getting the clutch line and not wanting to buy a $184 master/slave and line set-up from GM. I just bought a 1" wilwood master (which is requiered for my set-up) and now need to connected it to this PITA slave. I have heard that some have drilled and taped them with gret sucsess . so I'm here to ask: What size tool do I need and where do can I find them and also instruction or hits would be helpful too. Also anyone had a custom line made buy a local hose shop for a direct fit? I have a company named Hufca Inc that make custom braided hoses but I was wondering about price. Thanks, JR Quote Link to comment Share on other sites More sharing options...
piston Posted October 25, 2006 Share Posted October 25, 2006 i too will like to see this on paper. i heard people tap using 1/8. im in the same process.. Quote Link to comment Share on other sites More sharing options...
cho240z Posted October 25, 2006 Share Posted October 25, 2006 you can get a quick disconnect line from Mcleod for around 70 bucks, -4 an on the other side. easy, and you dont have to mess with your slave. Quote Link to comment Share on other sites More sharing options...
love-my-V8-280Z Posted October 25, 2006 Share Posted October 25, 2006 These were shared with me, I hope they can help you too. Quote Link to comment Share on other sites More sharing options...
Guest GM-7 Rocket Posted October 25, 2006 Share Posted October 25, 2006 you can get a quick disconnect line from Mcleod for around 70 bucks, -4 an on the other side. easy, and you dont have to mess with your slave. Well that sounds nice but I'm trying to reframe from spending $70 on a part that’s not even 2in^3 big. my budget is stretch enough as it is. I could get two more slave and have 3 shots at it for $70 . Anyone know where to get a fitting like the one in the pictures? Any more help? Thanks, JR Quote Link to comment Share on other sites More sharing options...
Guest GM-7 Rocket Posted October 25, 2006 Share Posted October 25, 2006 Hey I think I found my CURE !!!!! These look like they work and there cheaper then $70. http://www.fortesparts.com/specials.cfm GM 84-92 master slave stainless steel fitting Description: This -4 stainless steel fitting is made to replace the OEM plastic lines on 84up GM clutch pressure line. Installation Notes: These fittings fit many GM hydraulic pressure lines like in many trucks.. Special $35.00 they look right enough guess all give it a shot and buy them tomorrow. unless some one say no by then. let me know, JR Quote Link to comment Share on other sites More sharing options...
Bartman Posted October 25, 2006 Share Posted October 25, 2006 Here's Tim240Z's method: http://forums.hybridz.org/showthread.php?t=90585 Quote Link to comment Share on other sites More sharing options...
Guest GM-7 Rocket Posted October 26, 2006 Share Posted October 26, 2006 Ok it now accurse to me that I did say the I don't have the fitting that goes into the slave. I thought you could drill and tap the SLAVE it self. The wilwood master comes with a 3/8 outline size But any way I think I got it down now: GM 84-92 master slave stainless steel fitting $35 + shipping http://www.fortesparts.com/specials.cfm A 3/8 to 1/4 Coilhose Hex Reducer fitting (an-4 is 1/4" right?) from home depot $1 1/4 hard line 30" $7 from napa Stainless Steel Braided Line female an-4 fittings 91031842-4 12" Brake Line, Straight AN4 EA $9.95 + shipping http://www.speedwaymotors.com/xq/aspx/dept_id.13/display_id.1992/qx/product.htm Anyone know where I can get a shorter SS line like 8" or 10". Thanks, JR Quote Link to comment Share on other sites More sharing options...
that240guy Posted October 26, 2006 Share Posted October 26, 2006 Earl's brand in the summit catalog. They have all the stainless braided line you could ever want. Quote Link to comment Share on other sites More sharing options...
Guest GM-7 Rocket Posted October 26, 2006 Share Posted October 26, 2006 Earl's brand in the summit catalog. They have all the stainless braided line you could ever want. They're still not as cheap as http://www.speedwaymotors.com/xq/aspx/dept_id.13/display_id.1992/qx/product.htm But was I right? an an-3 fitting is a 3/16" fitting and a an-4 fitting is 1/4" fitting right? Thanks, JR Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted October 26, 2006 Share Posted October 26, 2006 But was I right? an an-3 fitting is a 3/16" fitting and a an-4 fitting is 1/4" fitting right? Thanks, JR Well, yes and no. An an-3 fitting can be used with 3/16 hardline and an an-4 used with 1/4 hardline. But the fitting itself has a different angle (37°) whereas standard fittings are 45°. You can't put an AN fitting on a coupling made for a standard fitting. You also need a different flaring tool for AN vs. standard fittings (37° vs. 45°) Not sure which question you are asking. Quote Link to comment Share on other sites More sharing options...
cho240z Posted October 26, 2006 Share Posted October 26, 2006 the mcleod part is the entire line. 22 inches long i think, all you need is the line and then a -4 an to 3/8 inverted flare adapter cody Quote Link to comment Share on other sites More sharing options...
piston Posted October 26, 2006 Share Posted October 26, 2006 where did you get that gm adapter from??? looks different from the mcleod adapter! These were shared with me, I hope they can help you too. Quote Link to comment Share on other sites More sharing options...
cho240z Posted October 26, 2006 Share Posted October 26, 2006 is the trans out of a lt or ls car?? my slave was completely different than the pics that love-my-v8-280z put up. had this funky quick disconnect thing on it Quote Link to comment Share on other sites More sharing options...
